Activity Forums Adobe After Effects Removing Pink Smudge on Lens
  • Removing Pink Smudge on Lens
    Posted by Sean Franklin on November 26, 2014 at 4:36 pm
    Hi all,
    I got a piece of B-roll footage and throughout most of the shots there is a pink smudge on the lens. Not sure how this happened but I was wondering if there is an efficient way of removing this?
    -Tim
    Tim Franklin
    Freelance Visual Effects Artist/ Video Editor
    Media Asset Manager, CBS Sports Network
    http://www.TimSFranklin.com
    Sean Franklin replied 11 years, 10 months ago 3 Members · 3 Replies
  • Graham Macfarlane
    November 26, 2014 at 6:23 pm
    If the smudge is transparent enough and fairly even (e.g non streaky), you should be able to draw a simple feathered mask around it on an adjustment layer, with the pen tool.
    Then you can apply some colour correction effects to the adjustment layer to counter the smudge.
    Edit: You might also want to apply a subtle sharpening effect to the adjustment layer too, if the smudge is noticeably blurring the image.
    Graham Macfarlane – CGI specialist
    Elyarch Ltd – London UK
    3D Studio Max | Vray | Pflow | PhoenixFD | After effects | Mocha
  • Tero Ahlfors
    November 26, 2014 at 6:52 pm
    Microfiber cloth, before shooting 😉
  • Sean Franklin
    November 27, 2014 at 2:04 pm
    Good idea, the color correction approach should work in the scenario. As for the cloth- you would think this would be considered before shooting, right? I’m just the post guy though…
    Tim
    Tim Franklin
