Activity Forums Adobe Illustrator Removing opacity from object
  • Removing opacity from object
    Posted by Ilona Wise on July 15, 2014 at 3:47 pm
    I traced an image (birds) from a picture. Copied the object (the anchorpoints/path) to new .ai file.
    Now I have a layer with a silhouette that I want to fill with a color.
    However when I fill it with e.g. black, it looks grey, as if it still has opacity applied, but I dont see how or why. Only a little gap within the silhoutte is black.
    Hope I explained it well. I am new to Illustrator.
    Here is a screenshot:
    Spencer Sy replied 11 years, 10 months ago 2 Members · 2 Replies
  • Ilona Wise
    July 15, 2014 at 7:28 pm
    I solved it 🙂
    Had to ungroup objects and then in layer panel could change opacity.
  • Spencer Sy
    July 19, 2014 at 11:10 am
    Hi Ilona. Can you try selecting the object then go to Object and select “Expand” so the artwork becomes more editable. Then try to Ungroup and select the parts you want to turn to black. I am not an expert but hope this helps.
    Graphic Designer Illustrator
    https://www.spencersy.com/
