Activity Forums Apple Final Cut Pro Legacy removing objects such as cables from scenes
  • removing objects such as cables from scenes
    Posted by Jeff Blasczyk on May 17, 2006 at 2:02 am
    I was wondering if anyone knows the best method for removing static objects such as orange electric cables and lens flares. I’m not sure if the camera is moving at all or how much. I have not looked at the footage yet, I will more than likely be picking it up tommorow to see if I can get rid of the stuff. It would be good points towards becoming the main editor on a budgeted feature in a few months.
    I have Adobe After Effects, Photoshop, and FCP 4.5 currently. Original material edited on Avid and will be transfered back to Avid.
    Jeff
    Max Frank replied 20 years, 4 months ago 3 Members · 2 Replies
  • David Roth weiss
    May 17, 2006 at 2:45 am
    Combustion would be your best bet.
  • Max Frank
    May 17, 2006 at 11:52 am
    CHV have some cloning software you can try – very affordable!
    W.
