Activity Forums Apple Final Cut Pro Legacy removing mask filter
  • removing mask filter
    Posted by Rick Amundson on July 14, 2006 at 3:18 am
    Hey all,
    I’ve made a rookie mistake and added the 1.78 mask filter to my entire feature film (105 min.). I would now like to remove the mask but have added other filters (color correction, speed changes, etc.) that I would like to keep. Is there any easy way to remove just the mask filter with out removing the other filters (i.e. remove attributes command) or am I stuck to opening every clip individually?
    Rick
    Michelle Weiss replied 20 years, 2 months ago 2 Members · 1 Reply
  • Michelle Weiss
    July 14, 2006 at 6:38 am
    uh-oh…
    Not that I know of, but this is slightly quicker:
    Leave your first clip with the filters on, select everything else in your timeline (that you want to remove the offending filter from) and ctrl+click and remove attributes-filters.
    Open the first clip and remove the offending filter, then ctrl+click and copy attributes-filters
    Now select the rest of your clips and Ctrl+click, PASTE ATTRIBUTES-filters.
    This way you won’t duplicate the existing filters, and you can bulk add them to the clips without the one you don’t want/
    To bad about the re-rendering time.
    *this only works if all your clips have the exact same set of filters applied to them….
    Good Luck!
    Please correct me creative cow-ers if there is a simpler way, I haven’t made this mistake myself!
