Activity › Forums › Apple Final Cut Pro Legacy › Removing interlaced look from 50fps material to use on 25fps project
  • Removing interlaced look from 50fps material to use on 25fps project
    Posted by Iiro Peltonen on December 19, 2011 at 4:30 pm
    This is my problem:
    A cameraman accidentally had his Panasonic P2-memorycard camera set on 50fps while he shot a days worth of documentary footage.
    He was supposed to shoot 25fps and now the footage ofcourse looks interlaced and the shutter speed is very high, when placed in a 25fps timeline. The shutter speed is not an issue, but the interlaced look is because I need to use this footage along with other 25fps material with a normal 1/60 shutter.
    Question:
    Does anyone know a way to somehow perhaps deinterlace this material or remove artificially every other frame from the footage so that I could get rid of the interlaced look. I don’t mind the high shutter because it’s mostly people dancing. I’ve been experimenting a bit, but haven’t gotten satisfactory results yet.
    John Christie replied 14 years, 9 months ago 2 Members · 2 Replies
  • John Christie
    December 19, 2011 at 5:48 pm
    Too Much Too Soon filters – Smart Deinterlace. The filters are free but you can donate to the developer.
  • John Christie
    December 19, 2011 at 5:49 pm
    OOOPS, Meant to say Blend Fields. Although Smart Deinterlace might be worth a look as well
