removing interference
Posted by Grzegorz Kwiatkowski on November 10, 2011 at 12:15 pmIs there any filter that removes interference from footage? It comes out sometimes when there are lines textures in the take. I am producing for the TV and that’s a big problem. I have to exchange these takes.
thanks
John Rofrano replied 14 years, 9 months ago 3 Members · 9 Replies -
John Rofrano
November 11, 2011 at 12:57 amDo you mean problems with Interlaced footage?
I’m not sure what “interference ” you are talking about.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
November 11, 2011 at 7:28 amMaybe I used a wrong word for this. When you film a surface/texture of an object that has lines very close one by one, you get this effect. They start to pixelate and interfere wich one another.
November 11, 2011 at 12:56 pmJohn,
below is the snapshot of footage I am talking about. Horizontal lines (stairs) in the background are interfering causing pixel-like effect. I had to exchange this take because technical checking at tv channel rejected this.
I know there is a specially dedicated filter for this, at least for Final Cut.
thanks
John Rofrano
November 11, 2011 at 1:15 pmThis can happen when you are shooting interlaced video and the lines and thinner than two fields which will cause them to flicker. You can right-click on the event and go into the Properties and enable Reduce Interlace Flicker and see if that fixes it. if not, you can try adding a slight Gaussian blur in the vertical direction only and see if it reduces it.
~jr
November 11, 2011 at 1:54 pmBoth solutions don’t work. I’ve just checked it. I know there’s a filter for this in Final Cut.
Bouke Vahl
November 12, 2011 at 1:12 pmThis is called moire.
You can make a matte (or soft wipe) for the affected area and put a bit of blur on the spot.
That takes care of it.Bouke
https://www.videotoolshed.com/
smart tools for video pros -
John Rofrano
November 13, 2011 at 2:38 pm[Bouke Vahl] “This is called moire.”
Ah… Vegas doesn’t have a moire filter. What would the matte look like that would remove it?
~jr
Bouke Vahl
November 13, 2011 at 4:19 pmYou did not get it.
A blur gets rid of the moire.
But you don’t want to blur the entire image, thus:
Create a matte, or wipe, to select the affected area, and apply the blur only there.And to see the moire it’s best to switch to composit on your client monitor. The limitations of composit video (as in SD broadcast) make it way worse than on a computer monitor or watching component / SDI.
Bouke
John Rofrano
November 13, 2011 at 9:40 pm[Bouke Vahl] “You did not get it.
Create a matte, or wipe, to select the affected area, and apply the blur only there.”Ah… yes. I get it now. The matte is just to limit what gets burred. Of course. 😉
~jr
