Removing Film Flicker from 8mm/16mm projected movies
I need a cheap fix here… I know that the proper way to transfer film to video is using a telecine. However, I’ve got some old 8mm and 16mm film that I shot using a DVCAM camera and want to remove the luminance flicker that results. It doesn’t need to be perfect, just reduced. Any ideas would be greatly appreciated. Thanks!
