Activity › Forums › Adobe Premiere Pro › Removing consistent beep using Audition
Posted by Tannie Low on October 17, 2012 at 5:19 pmI can see it, I’m just not sure how to spot-heal this automatically throughout the clip.
Tannie Low replied 13 years, 11 months ago 2 Members · 3 Replies -
Angelo Lorenzo
October 17, 2012 at 5:53 pmWhy not just use noise reduction? You can take a print on the beep then adjust the reduction profile to spike around that frequency, leaving the other frequencies barely reduced (the usual response is flat based on the noise print). There is no “auto healing”, just the noise reduction plugin.
Angelo Lorenzo
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks -
Tannie Low
October 17, 2012 at 5:57 pmI’m getting a “Please select a longer duration of audio for the noise print capture or change the ‘FFT Size’ setting within the Noise Reduction dialog.
I don’t see FFT Size, and my plan is to do a noise reduction capture for each of the three points. It doesn’t seem you can select multiple spots at once.
Tannie Low
October 17, 2012 at 6:00 pmOkay, so I adjust FFT Size to 512 and captured the noise point, but never having used this tool before I cannot figure out how to apply it throughout the entire track.
