Activity Forums Adobe After Effects removing camera shadow from shot
  • removing camera shadow from shot
    Posted by Tyguy6a84 on November 7, 2005 at 11:50 pm
    After reviewing my raw footage I have noticed that the camera’s shadow is seen just at the bottom right of the frame off a parked car’s back window. Is there a way to remove that shadow using After Effects 6.0? This shot plays a very important role in the scene so the shot has to be used. Reshooting is not an option.
    Tyguy6a84 replied 20 years, 6 months ago 3 Members · 4 Replies
  • Chris Smith
    November 8, 2005 at 1:45 am
    How long is the shot? Can you post a sample frame of it?
    Chris Smith
    https://www.sugarfilmproduction.com
  • Sally Lewis
    November 8, 2005 at 12:21 pm
    I recently had a similar situation where I needed to remove a shadow.
    I was able to accomplish this with AE 6.5 Standard. (Motion tracking would have helped but that option is with Pro)
    If you have access to the “Clone Stamp Tool,” it works much like it does in Photoshop. Create a comp, double click layer, and use the clone stamp to “paint” the shadow away using pixels from the background that matches. Choosing the “constant” option allowed me to keep the shadow out for the entire SOT.
    Hope this helps!
    Sally
    http://www.slewismedia.com
  • Tyguy6a84
    November 9, 2005 at 6:04 pm
    I can’t post any frames of it but I can e-mail you the .avi file of it. The shot runs approx. 8-10 seconds.
  • Tyguy6a84
    November 9, 2005 at 6:05 pm
    Can this be accomplished with After Effects Ver. 6.0?
