Activity › Forums › Adobe After Effects › Removing cables
  • Neil Hetherington
    March 10, 2010 at 11:09 am
    They are often ‘painted’ out frame by frame using the paint tool.
    Also make sure that you are using a good quality monitor to see the work with a high contrast ratio.
    Hope that helps a bit.
    Neil
  • Michael Szalapski
    March 10, 2010 at 1:58 pm
    I addition to the Mr. Hetherington mentions there is also a tool included in After Effects called CC Wire Removal, it’s designed to do just that.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Steve Roberts
    March 10, 2010 at 3:00 pm
    Google “wire fu” for more information on the technique in general.
