Activity Forums Apple Final Cut Pro Legacy Removing Blemish on Still Image in Final Cut?
  • Removing Blemish on Still Image in Final Cut?
    Posted by Nico Toll on October 4, 2011 at 11:10 pm
    I have uploaded a series of still images into Final Cut and it appears that my camera has a scratch or piece of dust on a part of the lens elements or sensor. (see attached picture. The blemish is above her elbow)
    Is there a way to create a mask that I can paste throughout my images to remove the blemish? Certainly, it would be wonderful if this wasn’t an issue or had been discovered before capturing a bulk of images.
    Tom Matthies replied 14 years, 11 months ago 3 Members · 2 Replies
  • Mark Laslo
    October 5, 2011 at 2:26 pm
    Since they are still images if you have photoshop you could set up an automated task to correct the issue and save as a new file (or the same file). Would save you from having to mask each file and probably cut down on some rendering too. Hope that helps.
  • Tom Matthies
    October 5, 2011 at 2:42 pm
    Also, check the sensor in your camera for dust next time. It will show up when using small lens apertures.
    E=MC2+/-2db
