Activity Forums Adobe Premiere Pro Removing Blade tool edits…
  • Removing Blade tool edits…
    Posted by Mark Pybus on September 16, 2009 at 8:46 pm
    Hello,
    I was curious as to whether or not there is a way to remove blade tool edits. Within Avid Media Composer you can map a menu item to the keyboard called ‘remove matchframe edits’. This command essentially removes the equivalent of ‘blade tool edit points’.
    Thanks in advance!
    John Hepworth replied 9 months, 1 week ago 6 Members · 6 Replies
  • Tim Kolb
    September 17, 2009 at 1:03 am
    Undo works well…
    If they’ve been there for a while, sometimes it’s easiest to just delete one part and untrim the adjacent clip to fill the empty space.
    TimK,
    Director, Consultant
    Kolb Productions,
  • David Dobson
    September 17, 2009 at 9:16 pm
    But no ‘remove matchframe edit’ equivalent, sorry.
  • Mark Pybus
    September 19, 2009 at 12:05 pm
    That is a feature that I’m missing quite a bit. I imagine it would be a fairly simple one to add.
    Thanks for your response.
    G5 Dual 1.8, 1.5GB RAM
  • Joe Lorenzetti
    August 31, 2016 at 7:46 am
    still not remove match edit eh?
  • Robert D’alexis
    August 31, 2016 at 2:33 pm
    Just go to “Timeline Display Settings” > Enable “Show Through Edits” > Right-click on an edit point > Click on “Join Though Edits” and voilà. 🙂
  • John Hepworth
    November 28, 2025 at 4:32 pm
    joining in from the future…
    in the way of editing, you check these things and then often forget what the answer is until years later
    despite my trying to keep track of these things in a google doc…
    the closest seems to be command lassoing the section with blade edits, getting the red roller bars, and hitting ‘delete’…
    now going to try it on a much bigger sequence
    https://docs.google.com/document/d/1x7osbrN1hUlxYkFIwEBKImFHQ-ggcUXAi8O-UVzg7F0/edit?tab=t.0
