Activity › Forums › Compression Techniques › Removing Audio Channels From MPEG HD (MXF) in Rhozet Carbon Coder
  • Removing Audio Channels From MPEG HD (MXF) in Rhozet Carbon Coder
    Posted by Chris Faiers on June 11, 2012 at 5:00 pm
    Hello
    First time post so I hope its not to badly written out.
    I am having to set up a transcode preset in Rhozet Carbon Coder where the output is a 1920 x 1080 P @ 25 fps MPEG HD (.mxf) with stereo audio (4 channels).
    Unfortunately I am unable to get the audio settings to change to only 4 audio tracks (it is greyed out on this setting so won’t allow any modification)
    Does anyone know of anyway around this/any audio filters I could use to remove the unwanted audio channels.
    Ideally I don’t want to go through editing software as it defeats the purpose of my transcode.
    Currently I am using the “XDCAM Exporter” preset within Rhozet Carbon Coder.
    Any help would be great!
    Marcello Mazzilli replied 13 years, 11 months ago 2 Members · 1 Reply
  • Marcello Mazzilli
    October 25, 2012 at 3:35 pm
    Wondering if you found a solution to this.. I need to handle hours of MXF with 8channels of ausio and I’d like to remove them to avoide Adobe Premiere to do the conforming.. Don’t need the audio
    siRoma di Marcello Mazzilli
    Corporate video productions in Italy
    http://www.siroma.com
