Activity › Forums › Adobe After Effects › removing an unwanted item from a video clip
  • removing an unwanted item from a video clip
    Posted by Debra Cohen on May 30, 2008 at 3:24 am
    What are the basic steps with removing a chair (an unwanted item) from a video clip?
    It’s the best clip and it mistakenly had a chair in it that doesn’t belong. I could replace it with the brown wood of a bureau/dresser that stands behind it. Is this something doable for a not very experienced user to do? (I’ve made an animated title with AE).
    thanks
    Debra Cohen
    https://mysite.verizon.net/devas_place/
    Mike Clasby replied 18 years, 4 months ago 4 Members · 4 Replies
  • Joey Foreman
    May 30, 2008 at 4:13 am
    Is the camera moving or locked down?
    Joey Foreman
    Editor/Animator
    Nowhere Productions, Athens, GA
  • Debra Cohen
    May 30, 2008 at 11:42 am
    The video camera was on a tripod and I believe the unwanted item is not intersected by the moving character/actress. The unwanted item/the chair is on the edge. If I let the clip go on longer then the frame would change or the camera would move.
    thanks
    Debra
  • Thorsten Miess
    May 30, 2008 at 5:03 pm
    Check out this tutorial: Simple Object removal
    its on https://maltaannon.com/ somewhere down there
  • Mike Clasby
    May 30, 2008 at 7:24 pm
    In case the footage has a little camera shake in it (don’t they always?), this tut will show you how to track the footage so you can have your replacement piece to match the video movement.
    https://library.creativecow.net/articles/kramer_andrew/Set_Extensions.php
    You can make the replacement in photoshop, either cloning out the chair with dresser wood, or replace it with something all together.
