Activity Forums Adobe Premiere Pro Removing a Still background video.
  • Removing a Still background video.
    Posted by Ariel Brener on October 2, 2008 at 8:21 am
    Hello pips,
    Well I have to remove a prerecorded background from a talking head shot.
    Here is the Talking head shot:
    Talking Head
    Here is the footage taken separately to be removed in Premiere.
    I want to replace this background with something else while he is talking.
    Background I want to remove and replace.
    Basically I need to KEY out this background from the top picture.
    I couldn’t find a way to do this simple thing.
    not in Premiere Pro CS3 and not in the Boris continuum Complete plugins!
    Come on people there must be a way!
    ADOBE MASTER COLECTION CS3
    Mike Cohen replied 17 years, 11 months ago 4 Members · 4 Replies
  • Mike Velte
    October 2, 2008 at 11:04 am
    It is going to be impossible to key out that background. The colors in the foreground (head) and background colors are way too similar.
    You could animate a mask in After Effects, but that would be extremely time consuming and the results would not be very clean.
    Reshoot in front of a green screen.
  • Ariel Brener
    October 2, 2008 at 11:41 am
    Hell no, it should be very simple.
    I dont need to use chroma key in this case. since I have the background shot seperatly I do have the data to be removed..
    its just that stupid Adobe didn’t embed such a simple action.
    You have it in other NLEs
    Anyhow I’m going to use this proggie:
    Serious Magic Ultra
    https://www.computervideo.net/dec04-4.html
    It should do the job…
    If some1 else has a plugin to premiere that does this simple task please replay.
  • Jeff Brown
    October 2, 2008 at 1:48 pm
    It’s typically called difference keying, and it typically doesn’t work.
    Good luck with it; personally, I’d plan for many hours of rotoscoping.
    -jeff
  • Mike Cohen
    October 4, 2008 at 6:15 pm
    I’m not sure the original post is written correctly. It sounds like he has done a key previously, since he has the original background image. Perhaps you need to delete your key effect from the foreground clip?
    Never know.
