Activity Forums VEGAS Pro Remove Water Spots
  • Remove Water Spots
    Posted by Rich Kutnick on January 8, 2008 at 1:52 pm
    After returning home from a wonderful trip to the land of “liquid sunshine” (e.g, Hawaii), I have begun to edit my footage (mini-DV). Unfortunately, the liquid sunshine evidently placed itself and dried on my camcorder lens several times and I guess that I neglected wipe it off as often as I should have. Nevertheless, several times throughout my footage I notice evident water spots (mostly when the camcorder is turned towards the source of light, and much less noticeable if at all when the source light is behind my back). Is there a Sony Vegas filter that can be used to eliminate or greatly reduce noticing the water spots? If not, what do you Vegas gurus suggest I do to help salvage this footage? Any ideas? I really do not want to over use an effect to call attention to the fact that I am trying to fix something in post, so I am hoping that someone can offer a realistic way to help me out. While the water spots ARE quite evident, they are not overpowering enough to TOTALLY ruin the shots, but enough to be slightly annoying. Thanks in advance!!
    Rich Kutnick
    VIDEO IMPRESSIONS
    Rich Kutnick replied 18 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
