Activity Forums Adobe Premiere Pro Remove Strobe or Alias from Video in CS5.5 or Encore
  • Remove Strobe or Alias from Video in CS5.5 or Encore
    Posted by Jennifer Tanner on November 22, 2011 at 9:01 am
    HD Video shot on Sony 1500 at 1080i, 29.97
    Apple 422 ProRes recorded on AJA Ki-Pro mini
    We’ve tried multiple encoding and field options (MPG2/DVD/AVI in Premiere CS5.5 and direct to Encore CS5.1) and can’t get rid of a “strobe” or alias effect that is appearing in our HD video.
    The video is aerial based video shot of skyscrapers/high rises. Seems we could be put into seizure if this strobe effect isn’t removed.
    Tried all combinations of flicker removal/anti-alias effect/flicker filter at 1.0
    Any ideas? Thanks in advance.
    Jeff Pulera replied 14 years, 9 months ago 2 Members · 1 Reply
  • Jeff Pulera
    November 22, 2011 at 3:31 pm
    Hi Jennifer,
    Hard to know what the problem is without seeing the video. Assuming the project settings for editing matched the footage? If there was a mismatch of frame rates or something, that could make the video look funky.
    All I can suggest is that in Adobe Media Encoder, when exporting to MPEG-2 for DVD, be sure to check the box for “Maximum Render Quality” at the bottom, as this improves the downscaling when going from HD to SD.
    Jeff Pulera
    Safe Harbor
