Activity Forums Adobe After Effects remove sticker on moving car
  • remove sticker on moving car
    Posted by Steve Gerges on October 21, 2015 at 3:46 pm
    Hi… i’ve been asked to remove a sticker on the side of a car (see image).
    The car is moving but the shot is static.
    At the moment i’m using the stamp tool in AE (frame by frame) but it’s a really slow process, and i was wondering if it’s the best solution or if anyone maybe has a tip for me on how to speed up the process (or use a different technique?)…
    i’m happy for any hint 😉
    cheers,
    Steve
    Steve Gerges replied 10 years, 10 months ago 2 Members · 4 Replies
  • Kalleheikki Kannisto
    October 21, 2015 at 5:33 pm
    Since the car is highly reflective and you can’t really expect to notice exactly what it is reflecting I would attempt to stretch the above and below sections to cover the text. Meaning, take the two areas marked with orange here and stretch the top one downward and the bottom one upward, keeping the top and bottom edges in place respectively (so that the other edges end up where the blue lines are). It is not necessarily going to be easy, with the car moving and all, but that’s how I would approach this.
  • Steve Gerges
    October 22, 2015 at 6:05 am
    Thanks Kalle that’s actually a pretty good idea…. !!! A friend of mine came up with the idea of doing (at least) one clean plate of the car, then use mocha to track the letters and put the clean plate on top (animating the reflections with some kind of warp). Or doing 3 clean plates (one in the beginning, in the middle and the end) and try to morph them (some sort) into each other while tracking. But your solution might do the trick as well. Will try that out today !
    Thanks again for the input.
    Steve
    October 22, 2015 at 6:29 am
    Another option would be to completely fake the reflection, taking it from the environment. If you have a frame in the footage that the car has completely passed (or is small in frame), you could create a precomp where the environment is moving and distorting as if it is a reflection, then track it onto the car and color correct to match. Soft edged masks would help in integrating it. This is not likely to be easy either but I can’t think of any easy fixes for this situation.
    (Actually this is almost the same as what your friend suggested.)
  • Steve Gerges
    October 22, 2015 at 9:38 am
    Thanks that did the trick…and it even looks pretty convincing 😉
    As u said. I took an empty frame (without car) tracked the letter in Mocha. imported the shape data to after FX. imported the emptyframe. added a polar coordinates and turbulent displace and some color correction to match the reflection oi the car…. and it works 😉
    thy again for the tip.
    Steve
