Activity Forums Adobe After Effects Expressions Remove source after execution
  • Remove source after execution
    Posted by Scott Mcgee on August 9, 2019 at 2:43 pm
    I have my script to import the first item from my folder.
    Once it has been imported another portion from the script is executed, after exporting, I want it to then remove the file from the folder.
    var myImportOptions = new ImportOptions();
    var myFolder = Folder(“Folder path”);
    var myFiles = myFolder.getFiles();
    myImportOptions.file = myFiles[0];
    app.project.importFile(myImportOptions);
    some forums suggest below, but it’s not removing my file.
    myFiles[0].remove()
    Any suggestions?
    Scott Mcgee replied 7 years ago 1 Member · 1 Reply
  • Scott Mcgee
    August 9, 2019 at 4:21 pm
    This was my issue
    I forgot to check this box.
    Because I use alerts to flag errors I only came about this, when I removed the alert and it finally told me I needed to check this box.
