Activity Forums Apple Final Cut Pro remove pulldown on hvx-900 footage
  • remove pulldown on hvx-900 footage
    Posted by Bret Williams on May 9, 2013 at 6:54 pm
    I have a shooter that may shoot on hvx-900 at 24p. It records 24p as 60i with pulldown. It will actually be recorded from the SDI port to a file via a kipro type box. In legacy, we could import files that had pull down with log and transfer, but opt to remove pulldown. How do you remove pulldown like legacy did, in FCP X?
    I still have legacy installed, but just trying to cut the cord whenever possible.
    Bret Williams replied 13 years, 4 months ago 3 Members · 3 Replies
  • Jeff Kirkland
    May 9, 2013 at 9:53 pm
    I was under the impression FCPX just does it automagically when you drop the footage in a 24p timeline? If I remember rightly there were posts that it looked sub-par on the screen but exported properly.
    I’m in a PAL country but it seems to handle 24p in a 50i stream from my ATOMOS Ninja ok.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • Jeremy Garchow
    May 10, 2013 at 12:40 am
    [Bret Williams] “It records 24p as 60i with pulldown.”
    If it is a KiPro, it should be able to remove pulldown on record and leave you with 24p material.
  • Bret Williams
    May 12, 2013 at 3:15 am
    It’s atomos samurai
