Activity › Forums › Adobe Premiere Pro › Remove noise from only part of a clip? mask?
Posted by Chris Kellam on September 8, 2013 at 5:36 pmHello, I’ve used neat video on a a project but am still having an issue in a particular part of the clip. I’m wondering how one would go about applying some kind of noise reduction, maybe a mask, I don’t know, in only a part of the clip rather than the whole clip. Here is a reference: (you can see the area I’m talking about on the side wall between the two characters). https://vimeo.com/74056754 Any help or method would be great!!!
Password is Imakefilms12!
Chris Kellam replied 13 years ago 3 Members · 6 Replies -
Angelo Lorenzo
September 8, 2013 at 6:38 pmYour best bet is After Effects because you’ll need more advanced masking techniques like luma (brightness) masking.
Also, your video is password protected and I see no password in your post 😛
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter -
Jovan Strel
September 8, 2013 at 8:12 pmi recently was working on footage that had huge problems with grain – HUGE
after all i learned i suggest you to get plugin called neat video
it will fix the grain you are having on the wallits a really good one, and will fix it easily – just sample the noisy region and will fix it – i dont think that there is gonna be a need to isolate the wall because of the way the plugin works
Chris Kellam
September 8, 2013 at 8:34 pmHi, yes, I used neat video on the clip yet I am still experiencing problems in that particular area.
Jovan Strel
September 8, 2013 at 9:29 pmlet me think —
i seems to me that this shot went through color correction process, so if there a chance that you have the original footage try adding the neat video effect to the original footage before color correction and after
also this footage seems to be of good quality, maybe 12 bit image or 16 so check to see if any 8 bit effects has been used on footage
i’ve seen simmilar problems before – the actual problem is not the noise but the color values that are getting clipped because of the way the effects are combined >>> if so reposition the effect layering
and if that fails to – what i would do if im in a time crunch –
is roto out the base of hair (remove the hair strands) and just replace the back wall
it a good thing she kinda static in that shotgetting a luma key out of this :/ — hmmm
yes the strands of hair are brightly lit but the color is simmilar to the wall color
i think roto would be quicker and then replace the wall image with a still frameif it is a longer shot or gets more complex, then go for the luma key
differentiate the midtone values with brightnes/contrast and levels effect until you get a varyation of gray colors where the strand of hair are close to white and the wall is closer to black and then replace the wall with a still image -
Chris Kellam
September 8, 2013 at 10:34 pmYeah I applied neat video before color and then used colorista 2 and 3 way color corrector in premiere which I believe are above 8 bit. This is 16 bit footage. Not sure what’s going on here. I might just go with that roto idea unless anyone has another??
