Activity Forums Adobe Premiere Pro Remove music from video using the original audio file?
  • Remove music from video using the original audio file?
    Posted by Even Martinsen on August 26, 2013 at 1:34 am
    Hi there,
    First time posting here, so sorry if I’m in the wrong forum or anything.
    Here’s my problem:
    I recently discovered several videos that I made many years ago when I was a kid. Since I was really unexperienced with videoediting back then, I put loud music over some scenes so it became impossible to hear what was being said in the background.
    Is there a way to filter out the music if I have the songfile? Using Premiere or some software to remove/mute the frequencies the song plays at or something?
    Thanks in advance!
    Even
    Angelo Lorenzo replied 13 years ago 2 Members · 1 Reply
  • Angelo Lorenzo
    August 26, 2013 at 2:24 am
    Put the audio track of the video in Audition’s multi-track and place the song under in track 2. Switch the polarity of track 2 and adjust the volume until you get the most amount of cancellation.
    This is probably the method to get the most detail back out of your original dialog track but you’ll probably cause huge amounts of damage to it as the human voice is a very broadband sound (spans the frequencies of audible sound).
    Alternately you could try using EQ to aggressively tune down the high and low end to give the music less power and apparent volume.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
