Activity › Forums › Adobe Audition › Remove Music from Dialogue if I have the original Music
  • Remove Music from Dialogue if I have the original Music
    Posted by Adam Haas on September 10, 2018 at 9:24 pm
    We experienced some data loss and we’re trying to re-create some files with what we have. The lapel mic audio is lost, but we have the exported audio (with baked music) and the music file itself.
    Is there any way I can apply a targeted/timed noise removal/cancellation on my exported audio, using the music file I have to get only the dialogue?
    Adam Haas replied 8 years ago 2 Members · 3 Replies
  • Kalleheikki Kannisto
    September 11, 2018 at 2:56 pm
    If you have the exact same music as what is mixed with the dialogue, you can reverse phase, match the level and zero out the music that way. I haven’t matched soundtrack timings in Audition. I guess you can do it manually, not sure if there’s a way to do it automatically. In Premiere you can align with the built-in sync tracks function or with PluralEyes (commercial plugin), not sure if that is sample accurate, since audio for video doesn’t really need to be, frame accurate is enough.
    Senior Graphic Designer
  • Adam Haas
    September 12, 2018 at 9:55 pm
    I found a video that explained reverse phase (I didn’t know what that was) https://www.youtube.com/watch?v=JF0IofTEii0
    From there I have a multi track file with my exported audio and the exact music file from Premiere (exact level, exact fade in, etc) and they aren’t canceling out like I would have imaged. Is there a step I’m missing?
  • Adam Haas
    September 12, 2018 at 10:24 pm
    I think I got it. I had leave the first portion of the audio not reversed and reversed the rest and it seems pretty close to perfect. Thank you for telling me about this concept.
