Activity Forums Adobe Illustrator Remove Jaggy Edges Photoshop
  • Remove Jaggy Edges Photoshop
    Posted by Matthew Joal on November 16, 2007 at 1:53 am
    I have an image which I need to remove the jaggy edges from. The jaggy edges aren’t bad enough that I think it has to be redone – I thought there might be a way to just smooth the edges out. I read someones post about using a blur and then moving the levels to sharpen the edges, however, I didn’t have any luck with that.
    Does anyone have any ideas?
    I have the psd online so you can see what I am trying to do.
    https://www.butlerfumc.com/test.psd
    Any help would be appreciated! Thanks!
    Matthew Joal replied 18 years, 10 months ago 2 Members · 2 Replies
  • Adolf Witzeling
    November 16, 2007 at 11:47 pm
    hi,
    try these settings in Illustrator CS2.
    Place the Photoshop picture in Illustrator.
    ADJUSTMENTS
    1: select the picture withe selection cursor…
    2: choose LIVE TRACE from the menue and in the Tracing options to start out, try these settings:
    Mode: Black and White/ treshhold 128/ Blur 1.3 pix
    TRACE SETTINGS
    path fitting: 2 pix
    minimum area: 10 pix
    corner angle: 20
    Play around with these setting, experiment, it’s fun…
    you can get all those different looks….
    take care,
    Adi
  • Matthew Joal
    November 18, 2007 at 2:51 am
    Great – Thank you for your help!
