Activity › Forums › Adobe After Effects › REMOVE GRAIN Recommended Render Settings – 12-core 32gb?
Posted by Sean Kapleton on November 19, 2010 at 5:35 pmHello
just wondering how I should set my processing and memory for this effect on ProRes 1080 50i 25fps (from fcp project HDV. The piece is 10 minutes in length.any help or advice would be awesome!
cheers2 x 2.66 Ghz 6-Core MacPro 5,1 (12-Core)
120GB SSD (OS)
ATI 5770 (hoping to get Nvidea card)
32GB 1333 Mhz DDR3 (x4 8GB sticks)
8TB RAID 0 Internal (x4 2TB Hitachi 7200)
BMD Decklink 3D
HDlink 3D DisplayPort
HP Dreamcolor
23″ ACDAndrew Smith replied 14 years, 9 months ago 3 Members · 7 Replies -
Kevin Camp
November 19, 2010 at 5:45 pmthis is a good place to start:
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Kevin Camp
November 19, 2010 at 5:46 pmdave, should we get a kickback from todd..?
or maybe we have…
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Sean Kapleton
November 19, 2010 at 6:07 pmHey Dave thanks for the reply
what i was saying is that it started as HDV 50i in FCP but was sent to Color and rendered back at ProRes 108050i 25fps so going into AE it is not HDV anymore.
Yes I am on CS5 as well
thanks
120GB SSD (OS)
BMD Decklink 3D
HP Dreamcolor
23″ ACD -
Sean Kapleton
November 19, 2010 at 6:08 pmyes thank you I actually had a chance ot read this as well but was just asking specifically about settings for this effect.
thank you2 x 2.66 Ghz 6-Core MacPro 5,1 (12-Core)
120GB SSD (OS)
BMD Decklink 3D
HP Dreamcolor
23″ ACD -
Kevin Camp
November 19, 2010 at 6:22 pmif you want to make sure all the cores are running at a high level, open the activity monitor (applications>utilities) as you render/preview. if the cpu usage graph is near the top, then your settings are good. if not, then tweak the settings, just don’t lower the ram to leave for other apps bellow 2gb or so.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Andrew Smith
December 21, 2011 at 4:11 pmHELLO GUYS,
SORRY ABOUT THE CAPS – RENDERING OBVIOUSLY 😉
SO RIGHT NOW I AM ADDING GRAIN TO A PRORES444 15 MINUTE RENDER OUT OF DAVINCI RESOLVE ON SOME GRADED R3D FOOTAGE THAT THE DIRECTOR WANTS A BIT GRITTIER.
MY QUESTION IS AGAIN ABOUT RENDER SETTINGS:
THAT IS, I HAVE IT SET TO MULTI PROCESSING AND LEAVING 10 GB FOR OTHER APPS IS THIS CORRECT ON MY 32GB 12-CORE? IT SAYS 4 HRS TO RENDER 🙁
