Activity › Forums › Adobe After Effects Expressions › Remove decimals
  • Posted by Paul Roper on June 17, 2013 at 2:59 pm
    Hello,
    I’ve been trying to simply remove the decimals from a number; eg. I want 9.9 rounded to 9, just killing off everything after the decimal point. So Math.round and toFixed don’t work; they do it “mathematically properly”. I’m trying to divide one number by another, but only want a whole integer result.
    I remember from the dim and distant past that BBC Basic (from the 1980s!) had a DIV function, that gave “the integer quotient of two items. The result is always an integer”, so 21 DIV 5 would give 4. I assume Javascript must have some equivalent of this? I suppose I could do a workaround and subtract the remainder from the first number:
    a=21;
    b=4
    c=a%b;
    (a-c)/b
    …but that’s a bit of a palaver!
    Any other suggestions, please?
    Paul
    Paul Roper replied 13 years, 3 months ago 2 Members · 3 Replies
  • Paul Roper
    June 17, 2013 at 3:17 pm
    Aha! After some searching around the world of Javascript, I found the rather bizarre:
    …so:
    n=16.99;
    ~~n
    wound give the desired:
    16
    – Paul.
  • Dan Ebberts
    June 17, 2013 at 4:29 pm
    How about Math.floor()?
    Dan
  • Paul Roper
    June 20, 2013 at 1:20 pm
    Thanks Dan!
    Incredibly, a Google search for ~~ returns no results. But I managed to find out that ~~ (a double bitwise NOT, apparently) and Math.floor perform the same thing.
    – Paul
