Activity › Forums › Apple Final Cut Pro Legacy › remove boom pole reflection in shot using final cut studio
  • remove boom pole reflection in shot using final cut studio
    Posted by Craig Carter on April 5, 2009 at 12:34 am
    I am looking for some help. Kinda new to final cut converting from avid and would like to know if you can
    remove an object such as boom pole thats in a shot. Let me explain further: I have a shot facing a barber with client in chair. Behind the barber you can see the boom pole in mirror. Is there any way to get the pole out of the shot using final cut or motion. ( after effects is out of the question don’t have it)
    Jason Diebler replied 17 years, 5 months ago 5 Members · 4 Replies
  • Bouke Vahl
    April 5, 2009 at 10:35 am
    if it’s a steady shot, it’s easy.
    Find a frame that is clean, make a still from that, and use a soft wipe to put it over the rest of the video.
    If it’s moving, you’ll have to motion track. That’ll be hell.
    Softening the bg (using masks) also might help to make it less noticable.
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pro’s
  • Arnie Schlissel
    April 5, 2009 at 6:24 pm
    You can do this in Motion using either the paint tools to clone from a clean frame, or by duplicating the layer & masking the clean portion over the one with the boom.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Max Frank
    April 6, 2009 at 3:40 pm
    CHV make a great, inexpensive clone tool that will allow you to
    clean this up right in FCP.
    https://www.lafcpug.org/reviews/review_chv_clone_plugin.html
    W
    osx 10.4.8 G5 2.0DP, 3.5GB RAM, FCP 5.1.2
  • Jason Diebler
    April 6, 2009 at 5:38 pm
    There’s a scene in “American History X” where you can see the entire film crew silhouetted in shadow… it seems so blatantly obvious that I wonder if it was even a mistake.
