Activity › Forums › Apple Final Cut Pro › remove blade cut (joing through edit)
  • remove blade cut (joing through edit)
    Posted by Jason Brown on April 4, 2013 at 11:25 am
    Is there an easy to remove a blade cut? (besides cmd+z)
    the only way I can see is to trim the clip to the next clip…but it still leaves 1 frame, so i have to lift from storyline (automatically fills with gap) then trim out the clip…then trim to the end.
    Seems crazy for such a simple edit technique.
    Neil Sinclair replied 13 years, 6 months ago 2 Members · 1 Reply
  • Neil Sinclair
    April 4, 2013 at 4:53 pm
    Assuming we’re working in the primary, my method is to shift delete the clip after the edit, T for trim and drag over Gap clip. Long winded for an frequently used technique I know!
