Activity › Forums › Adobe Premiere Pro › Remove black bars during slidepush transitions
  • Remove black bars during slidepush transitions
    Posted by Giuseppe Esposito on January 4, 2016 at 3:01 pm
    Message:
    Hi, I’m currently making a video to display the demo of a mobile app.
    I’m putting and animating a series of images inside an outer frame – namely an Iphone picture.
    My question is how can I configure push or slide transition between two different images avoiding to show black bars images. Those two images have a different ratio of the presentation, as they need to fit inside that Iphone frame and not to be full full-screen.
    This leaves “black bars” during the transition, and I can’t find a way to fill that gap between the png. I’m currently using the workaround of having a white background behind, but that obviously still keep a gap that actually doesn’t exist and shouldn’t appear.
    I’ve add a image to show the problem: I want to attach the left image directly to the right one, without bar in beetween. Thanks for any support
    Giuseppe Esposito replied 10 years, 9 months ago 2 Members · 2 Replies
  • Vince Becquiot
    January 4, 2016 at 4:59 pm
    Hi Giuseppe,
    For things like this, you may be better off with After Effects. If you plan on sticking with Premiere, I would forget the transition and just use keyframes to move the images together, then crop or mask if needed. The advantage of After Effects in this case is if you have a lot of these, you can just parent everything to the main image and they move together.
    Vince
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Giuseppe Esposito
    January 5, 2016 at 2:00 pm
    thanks for your reply. Unfortunately I’ve little or not experience with After Effects, and I had to finish this job today, so I didn’t follow your advice. When I’ll have a little more I will try.
    Meanwhile, I’ve been also suggested to use in Premiere a nested sequence with the resolution of those “inner” clip, which has resolved my problem quite smoothly.
