Activity › Forums › Apple Final Cut Pro Legacy › Remove audio tracks from quicktime
Posted by Daniel Edelman on December 5, 2011 at 2:39 pmI remember seeing a freeware app that would strip extraneous audio tracks from quicktime files. Anyone know what I’m talking about?
DanJason Brown replied 14 years, 9 months ago 4 Members · 8 Replies -
Mark Spano
December 5, 2011 at 2:51 pmQT Change is what you’re looking for – demo version is free for 8 clips at a time…
Daniel Edelman
December 5, 2011 at 3:15 pmThis is exactly what I need, but the demo doesn’t seem to work for me. Every file is greyed out, I can’t select it or drag-and-drop. Do you use it? Any ideas? I’ve sent and e-mail to the developer for help.
Massimo Croce
December 5, 2011 at 3:23 pmwith quicktime pro you can delete audio track.
open QT file in Quicktime pro 7 command+j select audio track you want delete and delete.Mac Pro “Eight Core” 2.26 (2009/Nehalem)
6GB ram Black Magic Decklink HD
final Cut Studio 3, Abobe After Effetcs, Davinci. -
Jason Brown
December 5, 2011 at 3:44 pmvery important note. You HAVE to “save as” to modify the file. If you simply do a save…it removes the link to the deleted tracks, but the file size remains the same.
Daniel Edelman
December 5, 2011 at 4:01 pmI know QT pro can do it, but I need a “batch” option because I have lot’s of files to alter.
Mark Spano
December 5, 2011 at 4:02 pmOpen QTChange
Click “Select source folder” (folder where your QTs live)
Choose tracks to delete (A1, A2, etc.)
Click “Do it”
done.Please be aware there is NO undo to this process, so make duplicates of your source footage prior to this process if you think you might want to go back at some point.
Daniel Edelman
December 5, 2011 at 4:48 pmI Found my error-
When batch exporting QTs form FCP, I neglected to give them extensions. QtChange cannot load the file without the .mov, even though quicktime can load and play the file. Lesson learned.FYI I plan to batch add the extensions with “A Better Finder Rename”, then remove the extraneous tracks with QTChange. This should be a big enough slap in the face to force me to be more careful with my settings!
Jason Brown
December 5, 2011 at 6:13 pm[Daniel Edelman] “add the extensions with “A Better Finder Rename”, “
Try name mangler…I love it…never tried better finder renamer.
