Activity Forums Adobe After Effects Removal of Motion Blur from a high frame rate conversion
  • Removal of Motion Blur from a high frame rate conversion
    Posted by John Mark on October 3, 2013 at 2:32 am
    I am thinking of purchasing Twixtor to do better frame rate conversions and I will only be working with converting 25fps to 50fps. Twixotr how ever can be time consuming when converting clips longer then 20mins, due to the fact that you must edit each cut/transition so you don’t get that “wiggle” effect on transition.
    https://www.youtube.com/watch?v=pcQQ8Yv9jj0&feature=player_embedded#t=0
    – This clip shows the steps on how to fix this, but it will take too long.
    Anyways, I have gone the simple way, by just using MPEG Stream clip to convert my YouTube clips from 25fps to 50fps. Since you are doubling the amount of frames, you get motion blur. Is there are way for After Effects CS6 to reduce this?
    -Thanks
    A News Graphic Lover
    John Mark replied 12 years, 7 months ago 63,522 Members · 2 Replies
  • John Mark
    October 3, 2013 at 4:00 am
    [Dave LaRonde] “If it’s 25P, and you don’t mind the look of the motion inherent at that frame rate and you absolutely, positively need 50fps footage, just drop your 25p clips into a 50p comp and render away, no Twixtor necessary.
    Yes, but this causes motion blur, and was wondering wether or not After Effects CS6 can reduce this?
    These clips I want converted to 50fps, so I am to able to use motion graphics at a higher rate. All the clips are progressive.
  • John Mark
    October 5, 2013 at 10:32 am
    I used After Effects to do the conversions, they turned out like the original. Using MPEG stream-clip was not doing the trick. So thanks Dave.
