Activity Forums Apple Final Cut Pro Legacy removal of moire/flicker effect
  • removal of moire/flicker effect
    Posted by Moztu on June 15, 2005 at 3:39 pm
    Hello to all,
    We are working on a project using quite a lot of still photos. They are high resolution photos (1600ppi) but have lots of detail and horizontal lines so when plaied they make a moire/flicker effect. We have tried using 10 FCP deflicker filters but still are not satisfied. What can we do? get a filter? we don
    Matt Sandström replied 21 years, 2 months ago 6 Members · 8 Replies
  • 8 Replies
  • Ed Dooley
    June 15, 2005 at 3:51 pm
    But you *should* use blur! Don’t use a gaussian blur, though. Use Motion Blur in Photoshop, or its equivalent in AE (Directional Blur?) and set it at 90 degrees, vertical only, 1 to 2 pixels. It’s the only way to do it.
    Ed
  • Paul Ingvarsson
    June 15, 2005 at 3:59 pm
    I agree – use a blur on your source psd file before you scale it to TV size – you will see great results….
  • Moztu
    June 15, 2005 at 4:24 pm
    Thanks a lot Ed and Paul, we will try that and see how it goes.
    moztu
  • Bob Auiler
    June 15, 2005 at 4:33 pm
    You might also want to try the blend fields filter, you can download it free from… http://www.mattias.nu/plugins
    Bob Auiler
    bob.auiler@mvpcollaborative.com
  • Matt Sandström
    June 16, 2005 at 10:03 am
    hey,
    i’m the author of that filter. any field processing filters have to be applied *after* any scaling and moving around has been done, which is not the order in which fcp normally renders effects. what you need to do is nest your clip with all the motion appled and apply “blend fields” or “reduce interlace flicker” to the nest. the reason a vertical blur works to apply even before motion is because it acts as a more agressive low pass filter, removing any vertical frequencies that might cause flicker and moir
  • Moztu
    June 16, 2005 at 12:31 pm
    thanks a lot Bob and Matt also. We might use that filter in the future since the above solution has helped for this particular project.
    moztu
  • David Fortin
    June 16, 2005 at 3:17 pm
    I found my still images looking a lot better if I REDUCED the resolution. You say they are “high resolution photos (1600ppi)”. I brought my “high resolution” images down close to 72 pixels/inch and they appeared a lot sharper. I didn’t even have to add blur to them when I did my moves.
    David
    Dual 2.5 G5 {OS 10.3.6}
    4.5 GB RAM
    NVIDIA GeForce 6800 Ultra DDL
    DeckLink SP
    ATTO ExpressPCI UL4S
    Medea Video Raid RT320
    Sony UVW-1800
    Pansonic AG-DV2500
    FCP Production Suite
    Media Cleaner Pro 6
    2 -Optiquest 21″ CRTs
    Bella EZ Keyboard
  • Matt Sandström
    June 16, 2005 at 3:27 pm
    for sure. that’s because fcp doesn’t low pass filter when scaling down. scale down in photoshop or similar to just a little bit more than you need for the absolute best results. or use the gaussian blur filter until it shows and then bring it back some. pretty much the same effect.
    /matt
    https://www.mattias.nu/
