Activity Forums Adobe Premiere Pro Removable Drive error message
  • Removable Drive error message
    Posted by Larry Andersen on December 15, 2010 at 4:48 pm
    I just installed CS5 was testing PP. When I try to make my Facilis 24D Fiber network drive be my scratch disk, I get this error: “The Location you have chosen is a removable drive. Please choose another location.” This is a drive has been used as a scratch disk for 5 years with FCP. Other removable drives on the system work just fine as scratch disks. I CAN save the project to the same disk; it’s just using it as a scratch disk that is the problem.
    Help.
    Larry
    Larry Andersen replied 15 years, 9 months ago 2 Members · 4 Replies
  • Vince Becquiot
    December 15, 2010 at 5:33 pm
    Hi Larry,
    Strange… Have you tried making a shortcut to that drive and using that instead?
    Or maybe a virtual drive?
    https://www.youtube.com/watch?v=9wpD3OdFs-0
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Larry Andersen
    December 15, 2010 at 6:13 pm
    Thanks Vince. Your reply reminded me that I forgot one critical detail. I’m on a Mac Pro, current OS.
    -Larry
  • Vince Becquiot
    December 15, 2010 at 6:27 pm
    Got it,
    Well, you could try creating a shared folder on the network drive, then mounting it as your scratch disk?
    Vince Becquiot
    Kaptis Studios
  • Larry Andersen
    December 15, 2010 at 9:29 pm
    I simultaneously had feelers out with Facilis. They suggested moving the Media Cache database, or changing the facilis drives to be DAW compatible – very simply done. Neither worked just restarting PP, but after doing both, a computer re-boot solved the problem.
    Thanks for your suggestions.
    -Larry
