Activity Forums Apple Final Cut Pro Legacy remote control
  • Posted by Doug Moldawsky on July 8, 2009 at 5:17 pm
    I need to control an FCP station from a remote viewing location. I’ve already extended the video/audio out form the aja kona but I need also to play,stop,rewind, etc. the system. ANy thoughts out there in the pasture? THanks.
    Dustin Lau replied 16 years, 10 months ago 6 Members · 14 Replies
  • 14 Replies
  • Jeremy Garchow
    July 8, 2009 at 5:46 pm
    Share your screen with iChat and a laptop in the remote location.
  • Russell Lasson
    July 8, 2009 at 5:52 pm
    Cool thing is that you don’t even need to open iChat. Turn screen sharing on in the sharing pane of system preferences. Change the settings so that remote people can log in with username and password. Then open safari and type in vnc://(insert ip address here). This works great and means you don’t need access to the other computer at all.
    I have found that the other computer should have a monitor connected and turned on, or FCP gives some crazy error that you don’t have a compatible graphics card.
    -Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
  • Doug Moldawsky
    July 8, 2009 at 6:04 pm
    RUnning 10.4.11 and I don’t see a screen sharing selection in the sharing pane? THere’s remote desktop, web sharing….but no “screen sharing”.
  • Jeremy Garchow
    July 8, 2009 at 6:08 pm
    Ah, Leopard only.
  • Russell Lasson
    July 8, 2009 at 6:10 pm
    Looks like it’s time for you to upgrade:) iChat sharing also requires 10.5.
    You might try to fine a free vnc program that will allow you to do what you want. But the integration into 10.5 is very useful.
    -Russ
    Russell Lasson
    Color Mill
    Salt Lake City, UT
  • Doug Moldawsky
    July 8, 2009 at 6:11 pm
    yes….found it on my newer system. I might have to buy remote desktop.
  • Doug Moldawsky
    July 8, 2009 at 6:14 pm
    thanks.
  • Russell Lasson
    Remote desktop is like $300. 10.5 is $129. Both would do what you want. I know where I would put my money.
    -Russ
    Russell Lasson
    Color Mill
    Salt Lake City, UT
  • Mike Weber
    July 8, 2009 at 7:50 pm
    This is a great tip, Russell. I knew about the Screen Sharing app, but didn’t know you could get there through a browser / IP address combo. If only there were a way to get system audio running through Screen Sharing, I could practically edit from anywhere, at least roughly. From what I can tell Screen Sharing does video only.
  • Jeremy Garchow
    July 8, 2009 at 8:13 pm
    [Mike Weber] ” If only there were a way to get system audio running through Screen Sharing”
    iChat will 😉 Run the audio out ot the audio in of the computer that is getting it’s screen shared, then in iChat turn the audio input from internal mic to line in.
    Alright, what ya got on that, Russel? 🙂
    Jeremy
