Activity Forums Creative Community Conversations remember the old days!
  • remember the old days!
    Posted by Bret Williams on May 3, 2011 at 3:47 pm
    While we’re all speculating on the new, why not remember the old?
    Some highlights of version 1.2.5… circa November 2000
    “manipulate video and images easily with graphical control of acceleration, velocity, and keyframes. With more than 75 built-in filters and keying effects and 60 predefined transitions, a text generator, support for qualified third-party Adobe After Effects plug-ins”
    “High-definition Television Support — By simply adding a new breakout box to the Pinnacle’s TARGA Cine card, Final Cut Pro editors can increase their system’s capabilities to deliver high-definition editing. ”
    And this one to all those that have said for 10 years that Apple never suggested digitizing to your onboard hard drive on a laptop or otherwise…
    “Portable Movie Studio — A PowerBook with Final Cut Pro allows you to create broadcast quality video almost anywhere. The PowerBook’s built in FireWire, large capacity internal hard drives, and brilliant display are perfect for on-site rough cuts, capturing footage or reviewing dailies. Full EDL support means your edit can easily transfer to traditional edit bay systems. ”
    read on here – https://replay.web.archive.org/200011100106/https://www.apple.com/finalcutpro/
    Dennis Radeke replied 15 years, 4 months ago 10 Members · 25 Replies
  • 25 Replies
  • Craig Seeman
    May 3, 2011 at 4:10 pm
    . . . and I remember all the Avid editors/facilities who laughed at the toy, thinking it would only be a “home” toy (kinda iMovie ish) and never a competitor . . . almost like all the FCP hand wringers are saying about FCPX.
    I remember convincing the Avid based facility I was engineer at, to get one FCP copy which they used for some of there simple “in house” low end work. Although I was gone before the changeover I believe they are an FCP facility now.
    The new “home toy” will be facilities setting up FCPX on the new Thunderbolt Quad Core iMacs to save costs.
  • Richard Herd
    May 3, 2011 at 4:23 pm
    [Craig Seeman] “The new “home toy” will be facilities setting up FCPX on the new Thunderbolt Quad Core iMacs to save costs.”
    And it’s gonna be AWEsome!
  • Bret Williams
    May 3, 2011 at 4:34 pm
    I never understood all those comments. I was using EditDV at home to edit my demo reels back in 1999. I was a freelance Avid editor and would take my XL1 to edit suites and dub the final project to mini dv to take home and add to my demo. I even started doing small DV productions with EditDV. When FCP came out I quickly realized it was a competitor, and actually had more high end features than composer. It had compositing modes, resolution independence, precomposing (nesting) , and even some animated text like animated tracking. Plus I could use my BorisAE in FCP. It had it’s limitations and gotchas, but so did Avid. If you were a little savvy, you could hook up a beta deck thru the svideo of a camcorder and digitize betacam as DV with full TC support. For 2-3k I had a system that was pretty similar to AVR77 or 2:1 meridian media composer suites which were still prominent. In some ways, better image quality. For the longest, Avid didn’t have any FireWire support. I was editing some broadcast work at local PBS where they shot on DVCam, then ingested it at 2:1 compression. They were running DV through compression making lesser quality, but more than doubling the file size. And that was considered broadcast quality. I had a G4 laptop that was better than that with FCP.
  • Ariane Fisher
    May 3, 2011 at 5:25 pm
    jaw-dropping!
  • Richard Dee
    May 3, 2011 at 9:10 pm
    I never upgraded past FCP 1.0. Did I miss an update?
  • Craig Seeman
    The new 27″ iMac has TWO Thunderbolt ports. With the built in monitor, it’s possible to have a 3 monitor setup. Of course TWO Thunderbolt ports is a major connectivity gain, sorta like two PCIe slots but better.
    I certainly think we’re going to see facilities with this along with FCPX.
    I really do think this is another chink in Avid “attraction” given the already limited I/O options they have. Given that one wont be able to install an nVidia card in an iMac, it can make FCPX look very attractive for speed compared to Premiere.
  • Dennis Radeke
    May 4, 2011 at 6:03 am
    [Craig Seeman] “I really do think this is another chink in Avid “attraction” given the already limited I/O options they have. Given that one wont be able to install an nVidia card in an iMac, it can make FCPX look very attractive for speed compared to Premiere.”
    Avid supports AJA and Matrox in addition to their own hardware, so I’m not sure that this is valid anymore.
    As for Adobe, CS5 was already 64-bit enabled and already took advantage of Grand Central Dispatch and all of the RAM – FCP X promises to catch up in that regard, so you’re applauding Apple for finally supporting their own platform 3 years after they made a 64-bit OS and hardware.
  • Craig Seeman
    May 4, 2011 at 12:48 pm
    [Dennis Radeke] “Avid supports AJA and Matrox in addition to their own hardware, so I’m not sure that this is valid anymore.”
    Not on an iMac. Remember COST is a big factor for many.
    Price of Avid plus MacPro
    vs
    Price of FCPX plus iMac
    Matrox and Blackmagic showed Thunderbolt products nearly ready to release.
    AJA showed that they are working on something.
    For many smaller facilities as well as others under budget pressure, FCPX, iMac with Thunderbolt willbe cost effective.
    This is in addition to MBP with Thunderbolt as well for those who need to edit in the field.
  • Dennis Radeke
    May 4, 2011 at 2:26 pm
    [Craig Seeman] “Not on an iMac.”
    Craig, what is preventing Avid or anyone else from running on an iMac? If Avid supports Matrox now and a thunderbolt version comes out, I think it a pretty good expectation that Matrox and Avid will support it. And as others have pointed out, it’s the talent of the editor and the quality of the tools that count not just the price.
    Sheesh, I’ve seen everything now. I’m an Adobe guy defending Avid on an Apple forum. Oh, the irony! 😉
  • Craig Seeman
    May 4, 2011 at 2:43 pm
    [Dennis Radeke] “If Avid supports Matrox now and a thunderbolt version comes out, I think it a pretty good expectation that Matrox and Avid will support it.”
    Avid’s history is SLOW to “certify” things. Avid may well be slow to “certify” Lion compatibility. Lion and FCPX may take advantage of things that will take some time to adopt.
    Adobe, on the other hand, will be right there from the start but Avid specifically has ALWAYS been SLOW to officially support new hardware as well as new OS.
Page 1 of 3
