Activity Forums Adobe Audition remaster music/generic eq/volume controls
  • remaster music/generic eq/volume controls
    Posted by Jason Zaloga on November 11, 2011 at 8:45 pm
    recently i was helped by someone who uses ozone. they explained to me how i could do it in audition.
    Step 1: Sharply drop the unnecessary bass frequency eq range from about 50hz to 20 hz
    (drop by about 20 dB)
    Step 2: Lower the bass eq from 20 to 160hz by about 5 dB or less depending on taste
    Step 3: Lower the overall volume by 1-1.5 dB
    Step 4: I compressed the overall dynamics so certain frequencies wouldn’t go past a
    certain volume (which is a bit advanced)
    are these in the plugins window and what are they called in audition?
    Jason Zaloga replied 14 years, 10 months ago 2 Members · 4 Replies
  • Angelo Lorenzo
    November 12, 2011 at 2:56 am
    Parametric EQ, Multiband compression, and Amplify.
    Angelo Lorenzo
    https://filmsfor.us – Helping you sell your film online
    Watch Steve Job’s Spirit Inside The iPhone 4S
  • Jason Zaloga
    November 12, 2011 at 3:39 am
    thanks.
  • Angelo Lorenzo
    November 12, 2011 at 5:30 am
    I should point out that none of the effects I mention do Mid/Side processing, that usually requires manually sending everything to a “master” bus that’s bussed to two additional busses: one with a stereo effect to only have mid, and another to only have sides. Then that’s piped out to the Master out.
    Ozone does it in-plugin which is a nice timesaver.
    Angelo Lorenzo
  • Jason Zaloga
    November 12, 2011 at 9:33 am
    ok. Mid/Side processing can it be done in audition.
    Is this the order of process?
