Activity Forums Apple Final Cut Pro Legacy relinking clips deletes aux timecode in FCP 6
  • relinking clips deletes aux timecode in FCP 6
    Posted by David Fish on June 19, 2007 at 1:10 am
    Bizzare problem…relinking clips deletes aux timecode.
    I attempting to reconnect master clips and their associated
    multi-clips (based on matching aux TC) from one system to another
    (both FCP6).
    The multi clips were created on “system 2” using media copied from
    “system 1”, where the material was originally captured (using FCP5).
    When the “system 2” project containing the multi clips is brought into
    “system 1”, everything looks fine OFF-LINE; master clips, subs,
    multiclips all come across with the aux TC.
    I am able reconnect the master clips to the original “system 1” files
    with no errors. The media is connected, but the aux TC is GONE from
    the master clips, making my multi clips completely out of whack, and
    also missing the aux TC.
    any thoughts?
    many thanks.
    David Fish replied 19 years, 2 months ago 2 Members · 2 Replies
  • Reg Wrench
    June 19, 2007 at 9:38 am
    Hi
    Am I right in thinking that Aux tc in FCP affects the master clips ie it writes itself into the original QT files, therefore your original files won’t contain the Aux tc so it will disappear. If you copied the files from System 2 to system 1 (ie. copy your copies back) then the aux tc should appear. Hopefully.
    Hope that helps…
    Reg
    2.7 Dual G5
    FCP 5.1.2
    OS 10.4.8
    4Gb Ram Kingston
    750Gb Graid SATA
    500Gb Graid Firewire 800
    Kona LS
  • David Fish
    June 19, 2007 at 5:12 pm
    yes, that seems to be it, thanks.
    d
