Relink to hi res files and rename file
I am in the process of linking to all my purchased audio in the project. I use the ‘relink’ feature to point to the unwatermarked audio, then manually relink each track. However, once Ive relinked, the filename remains the same, so when I look at the timelines I still see the _preview at the end of the filename, and makes it really difficult to figure out which tracks ive relinked and which ones i havent.
Does anyone have a better solution for this, or is it really this tedious?
