Activity › Forums › Avid Media Composer › Relink – audio suddenly offline
  • Relink – audio suddenly offline
    Posted by Sophie Dubois on November 24, 2008 at 12:49 pm
    This morning found all my voice-over off-line & can’t figure our how to link. VO was mysteriously (accidently) saved to Leopard HD, whereas other media is on external disk. I couldn’t figure out how to move VO (came from DVD) to ext HD, so I left it there. I can’t figure out how to relink now to my VO BIN.
    I’ve restarted. I’ve cleaned out ext drives (dump msr? guys & restartd) I’ve tried relinking w/ every possibility……nothing.
    thank you kindly!
    Sophie Dubois replied 17 years, 10 months ago 2 Members · 2 Replies
  • Job Ter burg
    November 24, 2008 at 1:53 pm
    On your Mac HD, do you see a folder named Avid MediaFiles or a folder named OMFI MediaFiles? Move the contents from either to the external drive. Make sure to place them in the right folders.
    Other than that, if this is stuff you imported from DVD, you might simply use Batch Import to reimport the files, and thereby revive the media for those clips (and all sequences linking to them).
  • Sophie Dubois
    November 24, 2008 at 3:14 pm
    thanks!!! it helped! everything solved.
