Reliablilty of p2 transfer in field
One concern I have about P2 or firestore is that there is no way to monitor your transfer from camera to the P2 store drive or firestore device on set. Since this is a new technology it concerns me.
Example: You shoot 2-8 gig p2 cards and then lay them off to P2 store drive. You will not know whether it really x-fered with no problems until you can play the material back from an edit machine/laptop or unless you can lay it off to a deck. Very time consuming. Yes you can play it in camera, but it is x-ferring out of the camera that has me worried.
My interest is in using this camera for a documentary when a working a couple of firestore or equivalent drives when released. But same problem. How do I 100% know that it x-fered properly if I can’t monitor easily on set? Especially when i would be dealing with 100gigs of data. Is the only solution to have a laptop on set?
Keith.
