Activity › Forums › Boris FX Particle Illusion › Regarding the LOOP TUTORIAL, short question
Posted by Llolbo on July 26, 2007 at 8:44 pmI will be very thankful if you could tell me how to RENDER into .PNG images as this tutorial describes>>> https://www.wondertouch.com/tutorials/PI%20Loop%20Tutorial%20V3/PI%20V3%20Loops%20Tutorial.htm
I’m a bit lost with that part, because when i render i get only the possibility to do it on following formats > JPEG, CMP …. but no PNG?!…
Thanks in advance
Llolbo replied 19 years, 2 months ago 3 Members · 7 Replies -
Elvis Deane
July 27, 2007 at 1:58 amAre you using version 3 of particleIllusion, or SE? SE has limited formats compared to 3.0, but you can save out TGA files with an alpha channel (might not show up in the drop down as I recall, but it does work if you just leave it at the default and type .tga after the filename).
Elvis Deane!
The Apprentice Magician’s Guide to particleIllusion
Wilbur of Wumbaberry -
Llolbo
July 27, 2007 at 1:03 pmactually my version is 3.0.1
I have TGA, maybe after rendering in TGA frames, i will use a third party application to batch TGA into PNG so i get the results.
In any case it will be useful to know how to do this directly from PI.
here is the project im working with:
http://www.netherworld-ro2.com
Im trying to LOOP the HEADER effect and the ANGEL ANIMATION’S FIRE, to get a continuos animation (until now without success) .
Any advises on how to get this to work?
Best Regards
lLOlBO
Alan Lorence
July 28, 2007 at 2:16 pmJust render to TGA. There’s no reason you shouldn’t be able to render PNG though.
Alan.
Llolbo
July 30, 2007 at 2:54 pmwell i dont get the option to save as PNG -.- thats the problem, and thats why i m asking for help. Is strange indeed as a friend of me has the option to do it…
Alan Lorence
July 30, 2007 at 5:02 pmSo you’re using particleIllusion 3.0, and there is no “PNG” option in the file types pulldown list when specifying the output filename? I don’t know how that would be possible.
Email wondertouch support, although I’ll say that you’re probably not using a registered (legal) version of the software. I apologize if I’m wrong, but we’ve never received a “I can’t save xxxxx image format” messages from a registered user.
But you’ve also missed the most important part of my previous message — the part that says “just save as TGA”.
Alan.
Llolbo
July 30, 2007 at 8:58 pmwell , actually the program is the same as the one from friend he installed it on both computers… we tested today again … without success, so after i reinstall it from the ORIGINAL CD i will come back to you.
And i thank you for your attentions.
