Activity Forums Apple Final Cut Pro Legacy refuses to render
  • refuses to render
    Posted by Digitalgodess on March 24, 2006 at 12:48 pm
    I am runnining Final Cut Pro HD 4.5 and having huge render problems on all media, text, video and picture stills. If I can get the render to work, it usually just jumps straight out, it renders for a bit and then quits saying File error: The specified file is open and in use by this or another application. I have no other applications open or running. Other times I just get General Error! This is driving me crazy as I am in the middle of a huge project which needs a lot of rendering. Please can someone advise.
    Digitalgodess replied 20 years, 6 months ago 2 Members · 2 Replies
  • Ron Dylewski
    March 24, 2006 at 1:48 pm
    I had a similar problem recently. The only fix I found was to replace the offending file, in my case it was an animation which was in QT format. I completely deleted it, re-imported it and that fixed the rendering problem.
    With that said, I started to have this same problem pop up yesterday on a project. I found that I could get the segments to render if I highlighted them and used “render selection.”
    Ron
    Photos, news, memories and musings on the great American Roadside experience
    https://www.theamericanroadside.com
    Are you a collector? Put your collection online for free at What A Collection.com!
    https://www.whatacollection.com
  • Digitalgodess
    March 25, 2006 at 8:46 am
    Thanks for replying.
    I can’t delete everything as my whole project is the edit that I have done on the time line, if I deleted everything I would have to start from the beginning again and its quite a complex edit. I’ve tried highlighting sections and to no avail. Help help still so stuck not sure if I am corrupting the project the more I try to render and the more error messages I get.
