Activity Forums Apple Motion Reflective floor
  • Reflective floor
    Posted by Robert Goodrich on September 30, 2008 at 4:59 pm
    I wish to apply the familiar reflective surface to the floor of my Motion compostition. I just can’t figure out how to do it. I’m referring to the reflection that appears as a polished floor, seen often in Apple web content and in iTunes browsing.
    I went through the entire library, and even dissected one of the templates to see what it was, but I couldn’t figure it out.
    Can someone assist me?
    Robert Goodrich replied 17 years, 12 months ago 4 Members · 5 Replies
  • Del Holford
    September 30, 2008 at 5:14 pm
    I’m a newbie in Motion but it seems to me if you re-import the image as another layer and use 3D camera, you could lay it down and use lighting effects to get the reflective look. HTH
    Del
    fire*, smoke*, photoshopCS3
    Charlotte Public Television
    del underscore edits at wtvi dot org
  • David Bogie
    September 30, 2008 at 8:35 pm
    It’s very tedious in Motion since Motion cannot do 3D shadows from objects.
    You need to know how to use Clone Layers but don’t expect the Clone to have 3D interactivity as you move your camera.
    See this page of tutorials for step-by-step:
    https://www.kenstone.net/fcp_homepage/fcp_homepage_index.html#motion
    Look for REFLECTION EFFECTS.
    It’s really only an illusion and it’s a sloppy hack. This is a failure of the application.
    also see the AE tutorials here on the cow. If you can follow the AE info, you can fake it in Motion
    https://library.creativecow.net/articles/kramer_andrew/reflections.php
    bogiesan
  • Robert Goodrich
    September 30, 2008 at 11:05 pm
    The effect is part of the “Float” template included in Motion. I thought I could just open that up and find it. Apparently, no.
    Thank you both for your responses, and the links. The search continues.
  • Peter Wiggins
    September 30, 2008 at 11:13 pm
    Go here:-
    https://www.motionsmarts.com/tutorials/reflection/reflection1.html
    Or if you want a plugin that does it, use the reflection plugin in FxFactory – there is a fortnight’s free trial
    https://www.noiseindustries.com/products/fxfactory/index.html
    Peter
  • Robert Goodrich
    September 30, 2008 at 11:17 pm
    Excellent.
    Much thanks.
