Activity › Forums › Maxon Cinema 4D › Reflections dissapeared
  • Steve Bentley
    August 18, 2018 at 11:04 pm
    Well first, this isn’t the same file as the golden eggs – there are lots of different and missing elements. So there is no way its going be identical. Oh ya and its coming from a version 4 revs ago – before the entire reflection engine was rewritten.
    I also don’t know the render set up for that file – how many bounces? render engine? reflection fall off? gloss coat?
    You can get there with either R14 or R18, its all in how you apply the reflections and the objects being reflected.
    I’ll bet the difference is in the Fresnel application.
  • Eric Oosterhof
    August 23, 2018 at 10:46 pm
    I know it isn’t the same file and I have tried what you said.
    I pretty much used the same settings even fresnel, only different softboxes.
    Even when I use presets in r19 I dont get the result I need. I’ve checked my videocard (AMD radeon 5800 HD), installed the new drivers.
    Still nothing It’s also not the fresnel.
    This is the best I can get. What am I doing wrong?
    File: 12668_spheres.zip
Page 4 of 4
