Activity › Forums › Maxon Cinema 4D › Reflections dissapeared
  • Eric Oosterhof
    August 12, 2018 at 7:57 pm
    But it’s still not even close to this:
    I created this the same way i created the other files with fresnel.
  • Steve Bentley
    August 12, 2018 at 8:00 pm
    Can you upload that file and maybe we can spot the difference?
  • Steve Bentley
    August 12, 2018 at 8:01 pm
    I’ve got a rev of R14 still on the system so I can look at it in that.
  • Eric Oosterhof
    August 12, 2018 at 8:03 pm
    I deleted version 11 and 13 and just created this file in a re-installed r19.
  • Eric Oosterhof
    August 12, 2018 at 8:15 pm
    It’s a different version, which is still working how it should: 12631_blackeggs.zip
  • Eric Oosterhof
    August 15, 2018 at 7:58 pm
    I really hope someone is able to figure this out. I’m stuck, but I keep searching myself. ????
  • Steve Bentley
    August 15, 2018 at 8:24 pm
    Hey Eric, I had to do the same thing again with the eggs. I had to delete or turn off the existing reflection which I assume has been converted from a legacy version, and replace it with a Beckmann and then everything works fine.
    To be fair it doesn’t look like your image (there’s no golden tone but that may be another matter). But I can see the cyc reflected, the eggs in each other and the cyc in the reflection of the reflected eggs.
    It looks like the legacy Fresnel is using a mix mode of Multiply – that’s an odd choice for a reflection and may be why its not very bright. Here’s the file.
    12647_blackeggsupdate.c4d.zip
  • Steve Bentley
    August 15, 2018 at 8:32 pm
    Actually if you just keep the legacy reflection and change the mix mode to normal or add, that does the trick too
  • Eric Oosterhof
    August 15, 2018 at 8:59 pm
    I have a render of your updated version, but i must say it is like it is ignoring the glossy part (its half matte half glossy) + in some area’s it really look funky (in hi-res details).
    I appreciate your response!
  • Eric Oosterhof
    August 18, 2018 at 9:52 pm
    Maybe someone else can help me out with this problem?
    It seems like a render problem to me.
    Any fanatics in the house?
Page 3 of 4
