Activity Forums Maxon Cinema 4D reflection issue
  • reflection issue
    Posted by Jason Stirret on April 9, 2011 at 11:17 am
    I have two questions:
    One, I cant seem to see objects through windows I have created, They are at 90% transparency…?
    Two, I have a building with glass windows that is reflecting another building I don’t want it to reflect…how can I turn off the reflectivity of a specific item in a scene.
    Thanks for any help!
    Adam Trachtenberg replied 15 years, 5 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    April 9, 2011 at 3:55 pm
    You should be able to see through something set to 90% transparency, unless you’re looking through multiple transparent objects and your ray trans limit is set too low (render>options). It could also be a strong specular highlight or reflection preventing your from seeing through.
    You can exclude reflection via the compositing tag. In this case you would put the tag on the building you want to exclude from reflection and drag the building with the reflective material into the tag’s Exclusion>Object box. The small icons to the right of the object you drag in the box control what’s excluded, e.g. transparency, reflection, refraction, heirarchy.
