Activity Forums Adobe After Effects Reflected lights of a (off screen) Disco ball… thoughts?
  • Reflected lights of a (off screen) Disco ball… thoughts?
    Posted by Adam Lewen on May 13, 2015 at 9:19 pm
    Hello!
    I have a task where I need to create a number of different sequences of the reflection of a party-like atmosphere (Disco ball) on a flat wall (simple black solid)
    It’s not very complicated task but I don’t wanna be repetitive and thought of asking here for different ideas of achieving
    here are some refs of what I have in mind: (again, i aim only at the reflected light. not the ball itself)
    https://tinyurl.com/knm5wdr
    https://tinyurl.com/l47j4z5
    https://tinyurl.com/l6be7yz
    My method so far is;
    Rotating an inverted Grid. Offsetting it’s Position with time* and treating those rotated shapes with color\glow\glints (2 layer of different grids will sell the effect, a fractal will add some atmosphere)
    But my post here is to bring up other ways. There are many ways to get such effect…
    Thanks a bunch!
    Adam!
    John Cuevas replied 11 years, 3 months ago 2 Members · 1 Reply
  • John Cuevas
    May 14, 2015 at 1:01 pm
    You might want to look at this very very old tutorial. Using Projection Layers to create a gobos and projector type effects
    Completely different approach that might be worth checking out.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
