Activity › Forums › Adobe Illustrator › refining a logo, Creating a texture and softening edges
  • Vincent Rosati
    June 4, 2015 at 3:50 pm
    You probably need to create an alpha channel mask in Photoshop.
    The basic process to mask this type of texture is:
    1 – Copy your flattened non-transparent image into a new project file or just duplicate the layer, so you can create a monochrome version of your image.
    2 – Select the duplicated layer and Image/Adjust/Channel Mixer/Monochrome.
    3 – Then, Image/Adjust/Invert.
    4 – Select All and Copy the inverted layer.
    5 – Open the Channels palette and click the Create New Channel button. Make sure this new alpha layer is selected, and paste your image into it.
    6 – Deselect the alpha layer, then Cmd+Click on the alpha layer or click the Load Channel as Selection button to make an alpha selection.
    7 – Now, go back to your original solid layer, highlight it in the Layers palette and click the Add Layer Mask button.
    However, this texture is very light, so you’d have to do a bunch of image adjustments (somewhere from steps 3 to 5) to achieve appropriate contrast in the monochrome image.
    It’s not easy to make a mask of this sort.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
