Activity Forums Adobe After Effects Referencing Parent Composition Properties
  • Referencing Parent Composition Properties
    Posted by Prestonchuckles on April 25, 2006 at 9:05 am
    I hope this makes sense:
    I have a composition with audio keyframes, so things will animate to the beat of the music I have. I have a nested composition in this comp. I want to connect the scale of something inside of my nested comp to the audio keyframes.
    When I pick-whip something inside the comp with the audio keyframes, I get this little expression:
    temp = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    [temp, temp]
    So I assume I need to change “thisComp” to … something. I tried root, rootComp, parent, parentComp, _root, _parent, everything I can think of.
    I can’t find any help online, because looking for AE with “referencing” brings up book reviews and parent finds parenting stuff.
    So please, please, please! if you can help me, I would be in your debt.
  • Dan Ebberts
    April 25, 2006 at 1:36 pm
    You have to use the actual name of the parent comp.
    Dan
  • Accountclosedduetonorealnameused
    April 25, 2006 at 3:06 pm
    if your parent comp was named “audio_comp” your new code would be:
    temp = comp(“audio_comp”).layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    [temp, temp]
  • Prestonchuckles
    April 25, 2006 at 5:01 pm
    That solved it perfectly. I suppose if I had paid alittle more attention to it I could have seen that. Thank you so very much.
    April 25, 2006 at 8:56 pm
    nah, the slightest bit of syntax can derail the whole thing.
