Activity Forums AJA Video Systems Reference loop
  • Reference loop
    Posted by Pierre luc Jutras gouin on May 14, 2010 at 5:27 pm
    I’m connecting a Kona LH (using the KL-Box) to a betacam UVW-1800. I’m also using a Horita BSG-50 to feed the reference. I just want to make sure my setup is ok, regarding the reference loop.
    Here is what I’ve done :
    1- Horita out to ref loop in the KL-Box
    2- ref loop of the KL-Box to the REF video input of the betacam.
    Here is where I have a doubt, should the 75ohm switch be turn on or off on the betacam or should I loop it back to the Horita.
    Also for the XLR analogue inputs, should I flip the switch to 600ohm or to 1k ohm, when connected to the Kona?
    Last question, for the RS-422 connection I’m using a stealth serial port connected by USB in the MacPro, would I gain anything by using the RS-422 connection from the KL-Box instead?
    Thank you,
    Bob Zelin replied 16 years, 3 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    May 14, 2010 at 9:24 pm
    [Pierre Luc Jutras Gouin] “Here is where I have a doubt, should the 75ohm switch be turn on or off on the betacam or should I loop it back to the Horita. “
    On and don’t loop back as the BSG50 is output only.
    [Pierre Luc Jutras Gouin] “Also for the XLR analogue inputs, should I flip the switch to 600ohm or to 1k ohm, when connected to the Kona?”
    Leave it @ 600 (switch to on).
    [Pierre Luc Jutras Gouin] “Last question, for the RS-422 connection I’m using a stealth serial port connected by USB in the MacPro, would I gain anything by using the RS-422 connection from the KL-Box instead? “
    Performance and perhaps accuracy.
    Set analog color space on in and out on your Kona Control Panel to betacam.
  • Bob Zelin
    May 14, 2010 at 11:32 pm
    #1 – make believe the Stealth port does not even exist. Use only the AJA RS422 port.
    # 2 – if you have anything unterminated when using a Horita BSG-50, it will not work. You MUST have the termination switch ON for this to work.
    These are the cables that you want to hookup – don’t ask, just do what I say –
    Black from BSG-50 to Beta 1800 Ref video input
    Black from BSG-50 to Beta 1800 VIDEO INPUT (I know that you are using analog component to work, but send black into the composite video input – just do it)
    Black from BSG-50 to Kona REFERENCE input, and TERMINATE the input with a 75 ohm BNC terminator.
    Dont’ forget – forget using the stealth serial port.
    Bob Zelin
